import problem
Since a couple of month, I have a strange problem :
When I import a model in any format, the object is phantom. It’s here in the arborescence, but I need to click on the eye icon or disable another piece to make it appear.
Do you have any suggestion for this tricky effect?
I m working on last K11.3.1 update
Thanks
F.
Did you try to reinstall or update your GPU driver? I have a similar issue when I duplicate the objects.
After reinstalling the driver and 11.3.1 update, the issue is fixed.
Ok, thanks for advice, I m going to check that :wink:
Hey,
I have had this issue too, assuming that you are importing models while on GPU mode, I would reccommend importing models while in CPU mode and then switching to GPU mode or if you do import while on GPU mode just switch to CPU mode and then switch back to GPU mode. These are the only work-arounds I have been able to find out.
Thanks vibhor for your comment. It works well in CPU mode.
